[GRASS5] grass5.0 and 5.1 merge question
    Helena Mitasova
    hmitaso at unity.ncsu.edu
    Thu Oct 10 08:51:26 EDT 2002
Markus Neteler wrote:
> Hi Peter,
> there is probably a little confusion.
No there is not - we have nviz in 5.1 that supports 3D vectors and then we have
nviz5.0
with Bob Covill's improvements and those two need to be merged before more work
is done,
in particular on integrating g3d.
It appears to me that merging grass5.1 and grass5.0 should
be a no. 1 priority right now before more work is done on each separately.
(e.g. if I want to do some enhancements to RST should I do it to s.surf.rst5.0 or
v.surf.rst5.1?)
I understand, that Radim does not want the merge before he has more of the vector
capabilities done,
but while the GRASS5.0 is being cleaned up, he may as well have enough done on
the vector side.
The milestones are set at http://grass.itc.it/grass51/index.html - maybe they
should be revised
and updated (I think there are few items even in phase 2 that are already done).
Glynn, Bernhard, do you have any advice on how to proceed with this?
It was already discussed but it ended up with no clear solution.
just a good advice on how and where to develop new capabilities in terms of
grass5.1 and grass5.0exp
would be helpful,
thanks a lot,
Helena
any advice
> Alfonso Vitti <alfonso.vitti at ing.unitn.it>
> Is working on G3D, while Radim is working on GRASS 5.1 3D vectors.
> Cheers
>  Markus
> On Thu, Oct 10, 2002 at 12:46:46PM +0200, Peter Paudits wrote:
> > Hello Markus and Radim,
> > thank you for information and CVS update of g3d. The updated version will be
> > the base for our work.
> > As you already know, Tomas Paudits will start to update nviz too. He wants
> > to append 3D volume visualization features (isosurfaces, walls, boxes,
> > profiles etc.) into current version of nviz. He decided to use actual
> > version of nviz in experimental grass5.1 sources from official grass5.1 page
> > for future work. Is it correct?
> > Radim, do you currently work on nviz development? Where we can get the
> > latest version of this with latest status of 3D vector features?
> > Thank you for your answers.
> > Peter Paudits
> Markus Neteler
> ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
>      Project on Predictive Models for the Environment
> Via Sommarive, 18        -      38050 Povo (Trento), Italy
> tel +39 0461 314 -520 (fax -591)          http://mpa.itc.it
