[GRASS5] g51: v.surf.rst
Markus Neteler
neteler at itc.it
Sat Oct 12 16:01:23 EDT 2002
On Sat, Oct 12, 2002 at 10:34:51AM +0200, Markus Neteler wrote:
> PS: GRASS 5.1 vector programming is really much easier than for 5.0!
> Most relevant functions are there:
> lib/vector/Vlib/level_two.c
> Use doxygen to get a HTML representation:
> doxygen Doxyfile
I have started to add some doxygen-style function descriptions to
and some other files. We should document all Vect_*() and
db_*() functions like that. Later on I'll implement a cronjob
to extract these docs onto the web site.
The (minimum) style of writing such docs is:
\fn int Vect_get_num_nodes (struct Map_info *map)
\brief get number of nodes
\return number of nodes
\param Map_info structure
...pretty easy. Note the exclamation mark to "notify" doxygen to
interpret this comment. doxygen is available here (GPL):
http://www.doxygen.org
or find it on your Linux distro.
Markus
