[GRASS5] NVIZ Development
Harald Wehr
hwehr at hs-harz.de
Tue Oct 15 01:33:25 EDT 2002
I just got the changes made by Bob Covill from Markus for testing. Here
some additional questions.
Compiling and installing went well.
First of all i tried to build a script with d.nviz:
d.nviz input=rpatch1 output=test name=NVIZ profile=south,north dist=2
ht=500 frames=10
The output is attached as "test".
Loading this file in NVIZ brings the output attached in "testoutput".
After that i tried to create a flight "by hand" from north to south and
had no luck. What are steps for that in the keyframe animation panel.
How do i alter the positions for certain keyframes?
Thanks for helping!
Harald
PS. Bob, i tried to send these questions directly to you
(bcovill at tekmap.ns.ca) but got the mail back. Tried it with two
different mail-adresses from different providers.
Type: application/x-java-vm
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20021015/fc99b0df/test.bin
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20021015/fc99b0df/testoutput.bin
