[GRASS5] NVIZ Development
Harald Wehr
hwehr at hs-harz.de
Wed Oct 16 01:34:49 EDT 2002
Hi Bob,
>Thanks for trying the d.nviz program. From your output it appears that
>you only ran it with one point (?). Like r.profile the profile= option
>should be a comma separated series of geographic coordinates tracing >the
>route. To generate these quickly you could run d.nviz with the "-i"
>option which will let you select the path interactively (like >r.profile)
>from the GRASS monitor.
I tried this too. But similar faults occur again. Just to be sure: I
have to produce the script with d.nviz. Then in NVIZ i go in the
"Scripting"-Menu, load the script and say play?
>I also notice that you are using dist=2 and ht=500. This will give a
>view almost directly down at the DEM. In other words the eye position >is
>2 meters behind and 500 metres above the scene center.
Yes. I got this.
>The email address you tried was correct. I know the site that hosts my
>email will not allow certain attachment types because of potential
>viruses. I suspect that it simply did not like the attachment type >(even
>though it was harmless)??
It did not work without any attachments too. I'm curious about that.
Just this mail came back and it does not have any attachments.
>I hope this helps. Let me know any other questions you might have.
Can I only test a "normal" flight from north to south by a script or can
this be done with NVIZ-gui too?
Thanks
Harald
