[GRASS5] GUI for GRASS
andy agena
andya at mac.com
Tue Oct 15 09:30:37 EDT 2002
hello all:
what about gnustep <http://www.gnustep.org/>? display postscript and
an interface builder so easy, even i'm able to use it.
andy
> Date: Tue, 15 Oct 2002 08:48:09 +0200
> From: Jan-Oliver Wagner <jan at intevation.de>
> To: grass5 developers list <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] GUI for GRASS
> On Mon, Oct 14, 2002 at 08:25:06PM +0100, Glynn Clements wrote:
> Bernhard Reiter wrote:
> I'd rather go with a better cross platform application framework.
> Thus the hottest candidate if I'd ever would approach this is wxPython.
> Unfortunately, wxWindows is also C++.
> right. Thats why Bernhard proposed wxPython, the Python wrapper for
> wxWindows. A language like Python works quite well for gluing
> functionality together for a GUI.
> I wrote a small wxPython sample for automatically building GUI dialogs
> from the --interface-specification of GRASS commands some time ago.
> If the Windows version of GTK+ is adequate, I'd suggest using GTK+.
> I also tested this and it works. However, you'll have a GTK-looking
> application under Windows which looks a bit alien.
> The big advantage of wxWindows is the concept of using native
> frameworks
> for GUI building. E.g. MSFC is used if the programm is executed on a
> Windows platform, GTK (or even QT) is used if you are on a GNU/Linux
> system. There is also a solution for MacOS.
> Jan
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20021015/58e91b97/attachment.bin
