[GRASS5] [bug #1349] (grass) r.slope.aspect will not compile Solaris 8 \i386
Glynn Clements glynn.clements at virgin.net
Tue Oct 15 15:52:01 EDT 2002
Request Tracker wrote:
> Subject: r.slope.aspect will not compile Solaris 8 \i386
> Platform: Solaris7/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> Hello,
> we compiled the GRASS 5.0.0 source code under Solaris 8 (i386 on intel
> machines). Everything seemed to be OK, but there were two compilation
> errors. The rest of GRASS works very nicely - but I need the
> r.slope.aspect module!:
> Compilation error in /src/raster/r.slope.aspect (ignored)
>                              /src.contrib/GMSL/NVIZ2.2 (ignored)
> Is this a common problem (has anyone else found this?).
No.
> Is it simple to recompile these modules seperately?
Yes. Once GRASS has been installed, you can use:
	gmake5 -i src/raster/r.slope.aspect
	gmakelinks5 -i
> What more should I do to track the errors.
Examine the output from "make" or "gmake5" for the actual error
message, and post it here.
Glynn Clements <glynn.clements at virgin.net>
