[GRASS5] [bug #1350] (grass) Cannot compile r.slope.aspect on Solaris 8 i386
Request Tracker grass-bugs at intevation.de
Wed Oct 16 06:33:28 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1350
Subject: Cannot compile r.slope.aspect on Solaris 8 i386
Platform: Solaris7/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
This is further to report 1349: more details.
This is the result from running (as suggested by Glynn Clements - thanks):
gmake5 -i src/raster/r.slope.aspect
  CMD     = /usr/local/source/grass-5.0.0/src/CMD
  UNUSED  = /usr/local/source/grass-5.0.0/unused
  HEADER  = head.i386-pc-solaris2.8
  ARCH    = i386-pc-solaris2.8
  GISBASE = /usr/local/source/grass-5.0.0/dist.i386-pc-solaris2.8
  VERSION = 5.0.0 August 2002
/usr/local/source/grass-5.0.0/src/raster/r.slope.aspect
  make -f OBJ.i386-pc-solaris2.8/make.rules
/usr/local/bin/gmake5 -i -all
  SRC     = /usr/local/source/grass-5.0.0/src
/usr/local/source/grass-5.0.0/src/raster/r.slope.aspect/cmd
make[1]: Entering directory
`/usr/local/source/grass-5.0.0/src/raster/r.slope.aspect/cmd'
gcc -I/usr/local/source/grass-5.0.0/src/include -O
-I/usr/local/include   -c main.c -o OBJ.i386-pc-solaris2.8/main.o
gcc: Internal compiler error: program cc1 got fatal signal 6
make[1]: *** [OBJ.i386-pc-solaris2.8/main.o] Error 1
make[1]: Leaving directory
make: *** [all] Error 1
This is the version of gcc we are using.
# gcc -v
Reading specs from
/usr/local/gnat312p/lib/gcc-lib/i386-pc-solaris2.6/2.8.1/specs
gcc version 2.8.1
Any ideas would be greatly appreciated - I am not expert enough to go digging in the source code and do not know what the gcc error message means! It is only r.slope.aspect of all the GRASS5 modules which does not compile.
cheers
Dan
-------------------------------------------- Managed by Request Tracker
