[GRASS5] [bug #1358] (grass) d.3d interactive more flexible than command line
Request Tracker
grass-bugs at intevation.de
Sun Oct 20 04:24:43 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1358
I notice that one can manipulate a lot more of d.3d in interactive
mode than from the command line. Bummer. [GRASS 5.0.0pre1 (May 2001)]
By the way, too bad one must specify the coordinates of the to=, and
can't optionally give an angle instead.
OK, I suppose one writes scripts like 3d.view.sh.
BTW, I hope that earth's curvature is applied, as I am doing 1 degree
wide blowups of 50 km away mountains looking horizontally directly
across, in order to identify which mountains they were in family
snapshots.
And I sure wish the cursor would stay put, each time one does a run in
interactive mode, and not jump back to the first item.
BTW, interactive mode should allow one to continue after saving a
3d.view setting.
Also Grass interactive programs should use the readline library so one
can use C-p to recall earlier entries, etc.
In conclusion, I would like to click on a certain mountain in the
image created by d.3d to find more about it, e.g. coordinates, but
can't.
http://jidanni.org/ Taiwan(04)25854780
--- Headers Follow ---
>From jidanni at dman.ddts.net Sun Oct 20 10:24:42 2002
Return-Path: <jidanni at dman.ddts.net>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 6F3A01394F
for <grass-bugs at lists.intevation.de>; Sun, 20 Oct 2002 10:24:42 +0200 (CEST)
Received: from msr.hinet.net (msr15.hinet.net [168.95.4.115])
by mail.intevation.de (Postfix) with ESMTP id D9CDC1C251
for <grass-bugs at intevation.de>; Sun, 20 Oct 2002 10:24:40 +0200 (CEST)
Received: from debian (61-227-44-135.HINET-IP.hinet.net [61.227.44.135])
by msr.hinet.net (8.9.3/8.9.3) with ESMTP id QAA27353
for <grass-bugs at intevation.de>; Sun, 20 Oct 2002 16:24:27 +0800 (CST)
Received: from jidanni by debian with local (Exim 3.35 #1 (Debian))
id 1838lu-00019L-00
for <grass-bugs at intevation.de>; Sun, 20 Oct 2002 13:37:06 +0800
To: grass-bugs at intevation.de
Subject: d.3d interactive more flexible than command line
User-Agent: Gnus/5.09 (Gnus v5.9.0) Emacs/21.2
Date: Sun, 13 Oct 2002 19:04:59 +0800 01:00:00 +0000 (GMT)
Message-ID: <87adlik3ac.fsf at jidanni.org>
Lines: 27
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=4.0 required=5.0
tests=DATE_IN_PAST_96_XX,RCVD_IN_ORBS,RCVD_IN_RFCI,
SIGNATURE_SHORT_DENSE,SPAM_PHRASE_00_01,USER_AGENT
version=2.41
X-Spam-Level: ****
-------------------------------------------- Managed by Request Tracker
