[GRASS5] [bug #1364] (grass) pre compiled binaries for IRIX does not work
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue Oct 22 03:42:02 EDT 2002
This bug has been fixed in the current CVS version (although the arrow
keys now do not work, but that is a minor inconvenience).
The workaround is not to start GRASS from an IRIX winterm, but from an
xterm or other terminal emulator.
E.g. type
xterm&
and in the new window that opens, type
grass5
The Esc and Enter keys will work in the xterm.
This is exactly the same as bug number 1240
http://intevation.de/rt/webrt?serial_num=1240
On Mon, 21 Oct 2002, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1364
> Subject: pre compiled binaries for IRIX does not work
> Platform: other
> grass obtained from: Trento Italy site
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: 5.0.0pre5
> The precompiled binaries installed just fine, however when you run grass it does not
> recognize the <esc> <enter> sequence.
> I have tried to run it from the origin2000 console and O2 workstation and a PC running the XWin32 program.
> We have no problem with the precompiled binaries for version 5.0beta11 as it runs fine.
> Gary Meyer
> ggmeyer at cosmos.unomaha.edu
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
