[GRASS5] ps.map problem
Michael Ash
mash at econs.umass.edu
Thu Oct 24 04:56:08 EDT 2002
I am using GRASS 5.0pre3 on Cygwin/Windows
I gave ps.map the following mapping instruction file
sites censusbg
color red
size 1
end
raster onsitegridlogscore
end
ps.map rejects the file with the following message:
PS-PAINT: using default configuration values.
: illegal color request
If I remove the color instruction from the mapping
instruction file, then there is no complaint and the map is
produced (without the desired color).
If I give the instructions interactively, then there is no
complaint and the map is produced (with the desired color)
Thank you very much for suggestions.
Sincerely,
Michael Ash, Assistant Professor
of Economics and Public Policy
Department of Economics and CPPA
University of Massachusetts
Amherst, MA 01003
Tel 413-545-6329 Fax 413-545-2921
Email mash at econs.umass.edu
http://www-unix.oit.umass.edu/~maash
