[GRASS5] Re: Grass 5.0.0 Binaries
Markus Neteler neteler at itc.it
Thu Oct 24 07:32:24 EDT 2002
(cc grass5)
[we are discussing why the 5.0.0 tarball is such big:
97547012 grass5.0.0_powerpc-apple-darwin6.1_bin.tar.gz
On Thu, Oct 24, 2002 at 03:34:52AM -0700, Jeshua Lacock wrote:
> On Thursday, October 24, 2002, at 03:08 AM, Markus Neteler wrote:
> > On Thu, Oct 24, 2002 at 02:59:12AM -0700, Jeshua Lacock wrote:
> >> Hi Markus,
> >> I was wondering if you were going to post the binaries - I have been
> >> getting requests.
> > well, the problem is the size. Did you run
> >  make strip
> > after compilation?
> Hello!
> I did not know about that step. It seems to do the job but -
> The distribution file is the same size. Any ideas?
Can you also check if you compiled with debugging symbols switched on?
grep COMPILE_FLAGS src/CMD/head/head.<darwin_something>
There should not be "-g" for a binary release. How to build binaries
is described in
 documents/release_rules.txt
Markus
