[GRASS5] [bug #1372] (grass) r.mapcalc: strange multiplication bug
Request Tracker
grass-bugs at intevation.de
Thu Oct 24 11:49:20 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1372
while working with r.mapcalc (in fact r.mapcalc new version)
we came accross a strange multiplication error:
The idea was to multiply all values in
plancS11.30m at Curvature
with 100000. The result seems to be nonsense.
On Thu, Oct 24, 2002 at 05:43:25PM +0200, Steno Fontanari wrote:
baez:insubri 171%r.info plancS11.30m at Curvature
| Layer: plancS11.30m Date: Wed Jan 30 16:58:19 2002 |
| Type of Map: raster Number of Categories: 255 |
| Data Type: DCELL |
| Rows: 3251 |
| Columns: 3871 |
| Total Cells: 12584621 |
| Projection: Transverse Mercator (zone 0) |
| N: 5157109 S: 5059581 Res: 29.9993848 |
| E: 1728648 W: 1612512 Res: 30.00154999 |
| Range of data: min = -466153.648586 max = 466153.648586 |
| Data Source: |
| Data Description: |
| generated by r.param.scale |
baez:insubri 172%r.mapcalc 'pippo2=int(plancS11.30m at Curvature*100000)'
baez:insubri 172%r.support -r pippo2
Updating the stats for [pippo2]
baez:insubri 173%r.info pippo2
| Layer: pippo2 Date: Thu Oct 24 17:26:50 2002 |
| Mapset: erdemolo Login of Creator: fontana |
| DataBase: /mpa_gdata/ssi/BIO/GRASS_DATA/data |
| Title: ( pippo2 ) |
| Type of Map: raster Number of Categories: 1082618906 |
| Data Type: CELL |
| Rows: 3251 |
| Columns: 3871 |
| Range of data: min = -1082618906 max = 1082618906 |
| Data Source: |
| Data Description: |
| generated by r.mapcalc |
Did we hit an upper/lower limit of CELL?
If so, r.mapcalc should refuse to write an output map.
Markus
--- Headers Follow ---
>From neteler at itc.it Thu Oct 24 17:49:19 2002
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id D97971394F
for <grass-bugs at lists.intevation.de>; Thu, 24 Oct 2002 17:49:18 +0200 (CEST)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by mail.intevation.de (Postfix) with ESMTP id 1B4861B6BA
for <grass-bugs at intevation.de>; Thu, 24 Oct 2002 17:49:17 +0200 (CEST)
Received: from orchestra.itc.it (orchestra [10.0.10.11])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g9OFnFX28107
for <grass-bugs at intevation.de>; Thu, 24 Oct 2002 17:49:16 +0200 (MET DST)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id g9OFnFt12041;
Thu, 24 Oct 2002 17:49:15 +0200
Received: (from neteler at localhost)
by thuille.itc.it. (8.11.6/8.11.2) id g9OFnFn24934;
Date: Thu, 24 Oct 2002 17:49:15 +0200
To: grass-bugs at intevation.de, Steno Fontanari <fontana at itc.it>
Subject: r.mapcalc: strange multiplication bug
Message-ID: <20021024174915.A24931 at itc.it>
References: <20021024174325.A6071 at baez.itc.it>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
User-Agent: Mutt/1.2.5.1i
In-Reply-To: <20021024174325.A6071 at baez.itc.it>; from fontana at itc.it on Thu, Oct 24, 2002 at 05:43:25PM +0200
X-Spam-Status: No, hits=-9.9 required=5.0
tests=IN_REP_TO,REFERENCES,SPAM_PHRASE_00_01,USER_AGENT,
USER_AGENT_MUTT
version=2.41
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
