[GRASS5] [bug #1389] (grass) v.cutregion.sh: resultant vector file(s) Comments are garbage
Request Tracker grass-bugs at intevation.de
Thu Oct 31 18:22:11 EST 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1389
Subject: v.cutregion.sh: resultant vector file(s) Comments are garbage
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
grass binary for platform: Compiled from Sources
GRASS Version: 5.0.0 (August 2002)
When using v.cutregion.sh, the resultant vector file, and region boundary area-vector (if saved) contain the same garbage in the vector Comments field.
Original line vector file imported with v.in.shape has no comment.
Should it grab Original Scale from the input vector as well?
eg:
v.cutregion.sh input=coastline output=milf_coastln -s -r
v.info milf_coastln
 | Layer:    milf_coastln                   Date: 11/01/02                   |
 | Mapset:   bathy                          Organization: GRASSroots organiza|
 | Location: milford                        Name of creator: v.cutregion.sh  |
 | DataBase: /home/hb/grass5_data/                                           |
 | Title:    Vector map: coastline ( milf_coastln)                           |
 |   Type of Map:  Vector (level: 2)        Number of Categories: 1          |
 |                                          Number of lines:      11         |
 |                                          Number of areas:      0          |
 |                                          Number of islands:    0          |
 |   Projection: New Zealand Map Grid (zone 0)                               |
 |            N:    5620507    S:    5600163                                 |
 |            E:    2109087    W:    2089091                                 |
 |   Source date:      2002                                                  |
 |   Original scale 1:1                                                      |
 |   Map threshold: 0.00076                                                  |
 |   Comments:                                                               |
 |     taß<øÿ¿05@ø@05@                                                  |
-------------------------------------------- Managed by Request Tracker
