[GRASS5] [bug #1301] (grass) Does not start up in text mode HP/UX 10.20
Request Tracker
grass-bugs at intevation.de
Fri Sep 13 07:02:35 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1301
Subject: Does not start up in text mode HP/UX 10.20
Platform: HP/UX
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 5.0.0
I had pre5 running fine on my HP 10.20 WS. After the upgrade, I do not manage to start grass in text mode (i.e I have to use the -tcltk switch), else I just get a :
Error opening terminal: xterm
I tried to remove the .grassrc5 file, but that resulted in also the tcltk mode aborting with the same error, if I start it with grass5 /gisdatabase/location/mapset, then it works fine.
I have had some other curses-related problems with the machine, it could be that that is biting me again. If anybody could tell me where the error-message is emitted, I'll go some hunting for the bug.
Morten
-------------------------------------------- Managed by Request Tracker
