[GRASS5] GRASS 5.1 conflicting types for `G_ask_datum_name'
Otto Dassau otto.dassau at gmx.de
Tue Apr 1 03:37:10 EST 2003
thank you Paul - you were right. After updating GRASS 5.0 from CVS the
this 'datum part'  of the GRASS 5.1 snapshot compiled properly.
but now occurs another compilation error with v.net.salesman
in GRASS 5.1.
make[2]: Wechsel in das Verzeichnis
»/daten/software/grass51/vector/v.net.salesman«
gcc -g -Wall  -Wall  -I/daten/software/grass51/include
-I/daten/software/grass51/dist.i686-pc-linux-gnu/include
-I/usr/include/pgsql -I/usr/include/pgsql/server/
-I/daten/software/grass51/dist.i686-pc-linux-gnu/include \
        -o OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c:23:19: proto.h: Datei oder Verzeichnis nicht gefunden
/daten/software/grass51/include/gis.h:36: warning: `GRASS_copyright'
defined but not used
make[2]: *** [OBJ.i686-pc-linux-gnu/main.o] Fehler 1
make[2]: Verlassen des Verzeichnisses
make[1]: *** [subdirs] Fehler 1
make[1]: Verlassen des Verzeichnisses »/daten/software/grass51/vector«
make: *** [default] Fehler 1
maybe another hint ?
Installation now:
GRASS 5.0 and 5.1 from CVS 1 Apr 2003 on Linux
thanks
 Otto
