[GRASS5] GRASS 5.1 conflicting types for `G_ask_datum_name'
Radim Blazek
blazek at itc.it
Tue Apr 1 07:49:12 EST 2003
Try to remove #include "proto.h" from main.c, the same for Steiner.
Radim
On Tuesday 01 April 2003 10:37 am, Otto Dassau wrote:
> Hi,
> thank you Paul - you were right. After updating GRASS 5.0 from CVS the
> this 'datum part' of the GRASS 5.1 snapshot compiled properly.
> but now occurs another compilation error with v.net.salesman
> in GRASS 5.1.
> make[2]: Wechsel in das Verzeichnis
> »/daten/software/grass51/vector/v.net.salesman«
> gcc -g -Wall -Wall -I/daten/software/grass51/include
> -I/daten/software/grass51/dist.i686-pc-linux-gnu/include
> -I/usr/include/pgsql -I/usr/include/pgsql/server/
> -I/daten/software/grass51/dist.i686-pc-linux-gnu/include \
> -o OBJ.i686-pc-linux-gnu/main.o -c main.c
> main.c:23:19: proto.h: Datei oder Verzeichnis nicht gefunden
> /daten/software/grass51/include/gis.h:36: warning: `GRASS_copyright'
> defined but not used
> make[2]: *** [OBJ.i686-pc-linux-gnu/main.o] Fehler 1
> make[2]: Verlassen des Verzeichnisses
> make[1]: *** [subdirs] Fehler 1
> make[1]: Verlassen des Verzeichnisses »/daten/software/grass51/vector«
> make: *** [default] Fehler 1
> maybe another hint ?
> Installation now:
> GRASS 5.0 and 5.1 from CVS 1 Apr 2003 on Linux
> thanks
> Otto
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
