[GRASS5] compile 5.1/ogr_api.h
John Gillette jg-Linux at triad.rr.com
Wed Apr 2 00:58:39 EST 2003
I am having a problem with grass51_exp_2003_03_29.  I configure pointing to
the gdal-config.  The problem is that there are a bunch of files that don't
get made because they can't find ogr_api.h.  It appears that ./config sets
HAVE_OGR (in include/config.h) which in turn triggers vect/dig_structures.h
to include ogr_api.h.  The problem apprears to be that nothing adds the path
to ogr_api.h.
If I manually add $(GDAL_CFLAGS) which is defined in Platform.make to the
local make file, this corrects the error.  The problem is that I have added
this 13 times so far and still going.  I assume this isn't correct.
Can someone help, please?
Red Hat 7.2
CFLAGS="-g -Wall" ./configure
--with-grass50=/home/john/grass50_exp_2003_03_29
--with-postgres-includes=/usr/include/pgsql
--without-fftw
--with-dbm
--with-dbm-includes=/usr/include/gdbm
--with-gdal=/home/john/gdal-1.1.8/apps/gdal-config
John
