[GRASS5] [bug #1784] (grass) grass_r_interface.html corrections
Bernhard Reiter bernhard at intevation.de
Mon Apr 7 06:43:38 EDT 2003
On Mon, Apr 07, 2003 at 11:58:22AM +0200, guest user via RT wrote:
> > If it is a clear bug you can fix it in the CVS directly.
> Where? I couldn't find it.
> web/statsgrass/ only has index.html and grass_r_insthints.html as far as I can
> tell.
So that is the real question. :)
Markus probably will answer that soon.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030407/ebc0aafa/attachment.bin
