[GRASS5] [bug #1784] (grass) grass_r_interface.html corrections
Markus Neteler
neteler at itc.it
Thu Apr 10 04:50:07 EDT 2003
On Mon, Apr 07, 2003 at 12:43:38PM +0200, Bernhard Reiter wrote:
> On Mon, Apr 07, 2003 at 11:58:22AM +0200, guest user via RT wrote:
> > > If it is a clear bug you can fix it in the CVS directly.
> > Where? I couldn't find it.
> > web/statsgrass/ only has index.html and grass_r_insthints.html as far as I can
> > tell.
> So that is the real question. :)
> Markus probably will answer that soon.
The files I copy manually into the web space to keep the
web CVS directory small. Probably I should move the entire
"tutorial" onto mpa.itc.it instead of grass.itc.it?
Markus
