[GRASS5] GRASS 5.0.2 released
Helena Mitasova hmitaso at unity.ncsu.edu
Fri Apr 11 10:25:10 EDT 2003
Moritz Lennert wrote:
> Markus Neteler said:
> >> > On Fri, Apr 11, 2003 at 11:25:33AM +0200, Markus Neteler wrote:
Moritz, when you are at it, can you also check the r.mapcalc to make
sure that it has all fixes (e.g. it writes the expression to the history
file?) and run nviz just to view some surface, to make sure that nothing
fundamental is broken there?
thank you,
Helena
> It installs without a glitch and rapid testing (d.*, r.thin, r.line, d.dm,
> nviz, g.select.pg, d.legend, d.what.vect (although I don't see any
> "flashing"...)) does not show any problems.
> Only found bugs:
> - when I launch v.to.db without any arguments, I get:
> PROGRAMMER ERROR: first item in gisprompt is <vector>
>         Must be either new, old, mapset, or any
> - the announced v.in.dgn module does no seem to be available
> Moritz
> Moritz
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
