[GRASS5] GRASS 5.0.2 released
Otto Dassau otto.dassau at gmx.de
Fri Apr 11 11:45:27 EDT 2003
Testing results for GRASS 5.0.2 on SuSe
1) SuSe 8.0:
GRASS 5.0.2 on SuSe 8.0 works fine.
- r.mapcalc writes the expression to the history file
- for NVIZ I needed 2 links to make it work
  ln -s /usr/lib/libtk8.3.so /usr/lib/libtk.so.0
  ln -s /usr/lib/libtcl8.3.so /usr/lib/libtcl.so.0
- PNG Treiber is OK
- Postgres works
- all other modules I was testing do not make any problems
2) SuSe 8.1:
Same as 8.0 but NVIZ does not work at all. I guess it is again
the tcl/tk8.4 problem, since you compiled with 8.3 ...
- everything else seems to be fine.
 bye
  Otto
