[GRASS5] GRASS 5.0.2 released
Moritz Lennert mlennert at club.worldonline.be
Fri Apr 11 13:12:38 EDT 2003
Helena Mitasova said:
> Moritz Lennert wrote:
>> Markus Neteler said:
>> >> > On Fri, Apr 11, 2003 at 11:25:33AM +0200, Markus Neteler wrote:
> Moritz, when you are at it, can you also check the r.mapcalc to make
> sure that it has all fixes (e.g. it writes the expression to the history
> file?) and run nviz just to view some surface, to make sure that nothing
> fundamental is broken there?
I'd already tested nviz, and everything seems to work fine for basic
operation.
r.mapcalc writes into the history file (as Otto already mentioned).
However, I can't use arrow keys in the interactive session. Is this normal
? (I don't know r.mapcalc that well).
Moritz
> thank you,
> Helena
>> It installs without a glitch and rapid testing (d.*, r.thin, r.line,
>> d.dm,
>> nviz, g.select.pg, d.legend, d.what.vect (although I don't see any
>> "flashing"...)) does not show any problems.
>> Only found bugs:
>> - when I launch v.to.db without any arguments, I get:
>> PROGRAMMER ERROR: first item in gisprompt is <vector>
>>         Must be either new, old, mapset, or any
>> - the announced v.in.dgn module does no seem to be available
>> Moritz
>> Moritz
>> grass5 mailing list
>> grass5 at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass5
