[GRASS5] GRASS 5.0.2 released
Helena Mitasova hmitaso at unity.ncsu.edu
Fri Apr 11 13:28:08 EDT 2003
Moritz Lennert wrote:
> >> Markus Neteler said:
> >> >> > On Fri, Apr 11, 2003 at 11:25:33AM +0200, Markus Neteler wrote:
> > Moritz, when you are at it, can you also check the r.mapcalc to make
> > sure that it has all fixes (e.g. it writes the expression to the history
> > file?) and run nviz just to view some surface, to make sure that nothing
> > fundamental is broken there?
> I'd already tested nviz, and everything seems to work fine for basic
> operation.
> r.mapcalc writes into the history file (as Otto already mentioned).
> However, I can't use arrow keys in the interactive session. Is this normal
> ? (I don't know r.mapcalc that well).
I would say that is a feature as it does not work in the old version of
r.mapcalc (pre3).
I don't think there is need to do anything about it as most people
use r.mapcalc on command line anyway,
thank you for testing
Helena
> Moritz
> > thank you,
> > Helena
> >> It installs without a glitch and rapid testing (d.*, r.thin, r.line,
> >> d.dm,
> >> nviz, g.select.pg, d.legend, d.what.vect (although I don't see any
> >> "flashing"...)) does not show any problems.
> >> Only found bugs:
> >> - when I launch v.to.db without any arguments, I get:
> >> PROGRAMMER ERROR: first item in gisprompt is <vector>
> >>         Must be either new, old, mapset, or any
> >> - the announced v.in.dgn module does no seem to be available
> >> Moritz
> >> Moritz
> >> _______________________________________________
> >> grass5 mailing list
> >> grass5 at grass.itc.it
> >> http://grass.itc.it/mailman/listinfo/grass5
