[GRASS5] FreeGIS-CD
Bernhard Reiter
bernhard at intevation.de
Mon Apr 14 10:03:31 EDT 2003
On Mon, Apr 14, 2003 at 03:48:03PM +0200, Markus Neteler wrote:
> On Mon, Apr 14, 2003 at 03:14:33PM +0200, Bernhard Reiter wrote:
> > The next FreeGIS-CD (v1.2.3) is in the test period
> > and will contain GRASS 5.0.1 to make sure we release stable packages
> > with basic testing.
> well, this were a pity as 5.0.1 only contains 2 changes. So you better
> include 5.0.0 ... :-( But why distributing partially oldish code?
> I thought the idea of the release branch is to release stable GRASS.
> Now FreeGIS doesn't follow the own ideas of it's maintainers (I remember
> that you are strongly recommending branches...)?
Of course we are following it.
And the quality of GRASS releases seems to have improved.
To sell a CD like the FreeGIS-CD you need to test it
on different platforms. If at all times improvements are accepted,
testing would start again and you can almost never release.
This why all serious Free Software distributions most of the time
contain older versions. It is a tradeoff decision to make.
Anyway I'm not deeply in the CD releasing process here,
we'll see how far we are and if GRASS 5.0.2 poses problems.
In any case there is going to be a next revision and hopefully
a fast update.
Demand for the CD is not that high that we could affort
more manpower on it.
Bernhard
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030414/3be57372/attachment.bin
