[GRASS5] 5.1: tcl error in parser
Markus Neteler
neteler at itc.it
Tue Apr 15 06:11:52 EDT 2003
while the module's GUIs in 5.1 run well on Redhat,
I face a problem on Mandrake 9.1 (tcl/tk 8.3.3):
When starting e.g. d.vect, selecting a map and
clicking on "Run", the following error appears:
can't read "opttype(1)": no such element in array
while executing
"if { $opttype($i) == "multi" } {
set domulti 0
for {set j 1} {$j <= $nmulti($i) } {incr j} {
if { $optval($i,$..."
(procedure "mkcmd" line 5)
invoked from within
"mkcmd "
invoked from within
".run invoke"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke]"
(procedure "tkButtonUp" line 7)
invoked from within
"tkButtonUp .run
(command bound to event)
The definition is in
lib/gis/parser.c
row 1236
I don't know what's wrong. Any hint/fix is welcome!
Markus
