[GRASS5] 5.1 CVS head errors on Solaris
Markus Neteler neteler at itc.it
Thu Apr 17 04:25:51 EDT 2003
On Wed, Apr 16, 2003 at 06:22:15PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > On Tue, Apr 15, 2003 at 09:02:11PM -0700, Chris Heg wrote:
> > > > > I have the following errors building the current 5.1 code on Solaris 8 sparc
> > > Line 873:
> > > LOC_CHECK_LIBS(mysqlclient,mysql_query,MySQL,$MYSQLLIBPATH,MYSQLLIB,,,,$ZLIB,$SOCKLIB,$MATHLIB)
> > Glynn,
> > may I ask to submit this as I have a really strange problem here:
> > GRASS 5.1.0-cvs:~/grass51 > autoconf
> > configure.in:39: error: possibly undefined macro: AC_MSG_ERROR
> > autoconf (GNU Autoconf) 2.53
> The manual for autoconf 2.57 still lists AC_MSG_ERROR as a valid
> macro, so it looks like a problem with your autoconf installation.
> http://www.gnu.org/manual/autoconf/html_chapter/autoconf_7.html#SEC88
Thanks for the hint. Surprising is that my 'autoconf' works for PROJ4/CVS.
It "just" fails for GRASS. Does this suggest anything 'aclocal.m4' related?
> In any case, I'll submit a fix.
Thanks,
 Markus
