[GRASS5] d.photo
Glynn Clements
glynn.clements at virgin.net
Wed Apr 23 12:51:12 EDT 2003
Radim Blazek wrote:
> > Actually, that's not entirely a joke. There is a legitimate argument
> > for sacrificing performance in favour of other properties. In this
> > case, simplicity. You can almost always get performance improvements
> > by replacing generic functions with multiple specific-case versions,
> > but doing so creates maintainence problems, and maintenance is GRASS'
> > biggest problem.
> Can I conclude?: GRASS needs RGB CT but we (you) don't feel to have
> enough human sources for GRASS maintenance and prefer not to increase
> complexity for now.
Whether or not the utility of such a feature would justify the
additional complexity is open to debate; I don't have a strong opinion
either way. I'm just saying that there are tradeoffs involved; IOW, it
isn't automatically true that anything which increases performance is
good; the other factors also have to be considered.
> So back to
> > Given that the speed difference between d.rgb and d.photo appears to
> > be almost entirely due to the additional time spent reading three maps
> > instead of one, it would definitely be worth looking into whether the
> > reading speed can be improved. If it could, that would benefit
> > everything.
> I commented
> stat = embed_nulls_nomask(fd, (void *) cell, row, CELL_TYPE, 0);
> in G_get_c_raster_row_nomask() and time fall down to 1.469s from
> original 6.930s. So all evil comes from NULLs.
> embed_nulls()
> -> G_get_null_value_row()
> -> G_get_null_value_row_nomask()
> and G_get_null_value_row_nomask() spends most of the time
> (2.161s if commented)
> It means that G_get_null_value_row() takes more than 230%
> of the time required for G_get_c_raster_row() (if NULLs not read).
Riiiight.
230% seems like a high price for backward compatibility.
> It must be possible to improve performance of G_get_null_value_row()
> but rasters are not my hobby.
get_row.c really needs a complete re-write, but that code is extremely
critical, and possibly quite fragile.
> BTW: It seems that raster values are masked by NULLs in current
> region resolution instead of original raster map resolution. I am
> not sure if it is good. That is probably more general problem of
> conversion of rasters to current region.
Right. My guess is that's a result of the null value support being
"tacked on". The nulls should be embedded before the map is resampled.
Glynn Clements <glynn.clements at virgin.net>
