[GRASS5] Problem compiling Grass51
maurosw at jumpy.it maurosw at jumpy.it
Mon Apr 28 10:43:02 EDT 2003
Hi to all,
I have a problem trying to compile last version of Grass51
(26/04/2003 cvs updated)...
make[1]: Entering directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib'
bitmap
make[2]: Entering directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib/bitmap'
make[2]: *** No rule to make target `OBJ.i686-pc-linux-gnu/bitmap.o', needed
by `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/dist.i686-pc-linux-gnu/lib/libgrass_bitmap.a'.
 Stop.
make[2]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib/bitmap'
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib'
make: *** [default] Error 1
Could someone help me?
Thank you
Mauro
________________________________________
Raddoppia la tua casella navigando con il numero unico! http://www.jumpy.it/Canali_J/Aiuto/articles.shtml?BXXCYXCYAH/art903
