[GRASS5] Problem compiling Grass51
Glynn Clements
glynn.clements at virgin.net
Mon Apr 28 13:03:25 EDT 2003
maurosw at jumpy.it wrote:
> I have a problem trying to compile last version of Grass51
> (26/04/2003 cvs updated)...
> make[1]: Entering directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib'
> bitmap
> make[2]: Entering directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib/bitmap'
> make[2]: *** No rule to make target `OBJ.i686-pc-linux-gnu/bitmap.o', needed
> by `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/dist.i686-pc-linux-gnu/lib/libgrass_bitmap.a'.
> Stop.
> make[2]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib/bitmap'
> make[1]: *** [subdirs] Error 1
> make[1]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib'
> make: *** [default] Error 1
> Could someone help me?
You have to run "make mix" or "make copymix" first.
The "grass51" repository only contains those files which are new or
have changed in 5.1; everything else has to be linked or copied from
the 5.0 source tree.
Glynn Clements <glynn.clements at virgin.net>
