[GRASS5] Problem compiling Grass51
    maurosw at jumpy.it
    maurosw at jumpy.it
    Tue Apr 29 03:49:24 EDT 2003
After "make copymix" (Grass50 cvs updated and Grass51 cvs updated)
I have this problem:
gcc -I/home/rpms/GRASS/gdal-1.1.8/ogr/ -g -O2  -Wall  -I/home/rpms/GRASS/gdal-1.1.8/ogr/
-I/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/include -I/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/dist.i686-pc-linux-gnu/include
  -I/home/rpms/GRASS/gdal-1.1.8/port -I/home/rpms/GRASS/gdal-1.1.8/core
-I/home/rpms/GRASS/gdal-1.1.8/ogr -I/home/rpms/GRASS/gdal-1.1.8/ogr/ogrsf_frmts
-DUSE_GDAL_H  -I/usr/local/pgsql/include/ -I/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/include
        -o OBJ.i686-pc-linux-gnu/input2d.o -c input2d.c
input2d.c:194: conflicting types for `IL_create_bitmask'
interpf.h:70: previous declaration of `IL_create_bitmask'
/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/include/gis.h:36: warning:
`GRASS_copyright' defined but not used
make[3]: *** [OBJ.i686-pc-linux-gnu/input2d.o] Error 1
make[3]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib/rst/interp_float'
make[2]: *** [subdirs] Error 1
make[2]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib/rst'
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib'
make: *** [default] Error 1
>-- Original Message --
>From: Glynn Clements <glynn.clements at virgin.net>
>Date: Mon, 28 Apr 2003 18:03:25 +0100
>To: maurosw at jumpy.it
>Cc: grass5 at grass.itc.it
>Subject: Re: [GRASS5] Problem compiling Grass51
>maurosw at jumpy.it wrote:
>> I have a problem trying to compile last version of Grass51
>> (26/04/2003 cvs updated)...
>> make[1]: Entering directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib'
>> bitmap
>> make[2]: Entering directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib/bitmap'
>> make[2]: *** No rule to make target `OBJ.i686-pc-linux-gnu/bitmap.o',
needed
>> by `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/dist.i686-pc-linux-gnu/lib/libgrass_bitmap.a'.
>>  Stop.
>> make[2]: Leaving directory `/home/rpms/GRASS/Sept2002/grass51_exp_2003_04_26/lib/bitmap'
>> Could someone help me?
>You have to run "make mix" or "make copymix" first.
>The "grass51" repository only contains those files which are new or
>have changed in 5.1; everything else has to be linked or copied from
>the 5.0 source tree.
________________________________________
Raddoppia la tua casella navigando con il numero unico! http://www.jumpy.it/Canali_J/Aiuto/articles.shtml?BXXCYXCYAH/art903
