[GRASS5] [bug #1834] (grass) v.cutter output in 5.0.1 is not correct
Request Tracker
grass-bugs at intevation.de
Wed Apr 30 09:19:03 EDT 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=1834
Subject: v.cutter output in 5.0.1 is not correct
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.0.1
The hypotetical bug is shown in v.cutter. Under some conditions the output between
v.cutter(5.0pre3, the OLD, and compiled locally) and v.cutter(5.0.1, the NEW) are differents.
The two vector files involved are a rectangular frame which cutting an irregular polygon and are
managed by those two commands.
OLD: v.cutter -u cut=frame data=buff_temp out-buff_temp2
NEW: v.cutter cut=frame in=buff_temp out=buff_temp2
If the OLD command create the right answer, the NEW one create a polygon which denote the
lacking of some vertex closing abruptly the polygon.
I have for people involved in the solution of this problem two pdf files with the two
different outputs.
-------------------------------------------- Managed by Request Tracker
