[GRASS5] v.overlay
Radim Blazek blazek at itc.it
Fri Aug 1 08:47:36 EDT 2003
v.overlay intersects 2 area vectors. Each area in the output map
has 3 categories: link to a new table, and categories of both input maps.
Attribute table also contains categories from input maps.
Problems could appear if Vect_line_intersection() fails or if any
output area is so small that calculated centroid falls outside,
because of finite-precision numbers (double).
Radim
