[GRASS5] grass 5.1 mix-linking errors
Hamish
hamish_nospam at yahoo.com
Fri Aug 1 23:16:32 EDT 2003
> > > Hi, upon 'make mix' for GRASS 5.1 I get the following errors, all seem to
> > > be due to missing recursed subdirectories in the 5.1 tree.
> > cd raster/r.le/r.le.setup
> > cvs up -dP
> > cd ../../../
> > make mix
> Ah, now I got it. The -P is the *problem* in this case
> as it deletes empty directories (it's empty initially
> so I'll add a small README there).
ok, that's it. It all works now.
Hamish
