[GRASS5] Let's publish 5.0.3
Bernhard Reiter bernhard at intevation.de
Fri Aug 8 12:02:02 EDT 2003
On Fri, Aug 08, 2003 at 04:34:01PM +0100, Paul Kelly wrote:
> On Fri, 8 Aug 2003, Markus Neteler wrote:
> > The further procedure might be:
> > - release 5.0.3 soonish
> > - rename 5.1.0 to 5.7.0
> > - open a new 5.3.0 release branch (with NVIZ updates, proj updates etc)
> I think we could just release 5.3.0 from the CVS HEAD.
Might make sense in this special case
as 5.3.0 is an "experimental" release
because of the numbering anyway.
> It is a lot of work
> adding things to a release branch and we have seen that important things
> can get left out by accident.
Branching actually is a cheap process itself
but usually a branch should not live long.
We need that 5.0.x branch, because it turned out stability is so important.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030808/ed59a782/attachment.bin
