[GRASS5] r.in.gdal compile problem
William K woklist at charter.net
Fri Aug 8 22:33:13 EDT 2003
With GRASS 5.0.3 CVS (7-19 and a couple earlier versions) I can't get
r.in.gdal to compile.  I get an illegal indirect reference from libgis
to libgrass:
gcc
-L/Users/williamk/Documents/src/unix/GRASS/grass50_exp_2003_06_28/src/
libes/LIB.powerpc-apple-darwin6.6  -o
dist.powerpc-apple-darwin6.6/etc/bin/cmd/r.in.gdal
OBJ.powerpc-apple-darwin6.6/main.o
OBJ.powerpc-apple-darwin6.6/gbgetsymbol.o
OBJ.powerpc-apple-darwin6.6/gdalbridge.o
OBJ.powerpc-apple-darwin6.6/make_loc.o \
         -L/usr/local/lib -lgdal.1.1 -lgeotiff -ltiff -lgproj
-L/usr/local/lib -lproj  -lgis  -lintl -lI  -lz
ld:
libes/LIB.powerpc-apple-darwin6.6/libgis.a(color_rule.o) illegal
reference to symbol: _G__color_free_fp_lookup defined in indirectly
referenced dynamic library /usr/local/lib/libgrass5.0.dylib
ld: warning multiple definitions of symbol _CSVGetFileFieldId
/usr/local/lib/libgdal.1.1.dylib(cpl_csv.o) definition of
_CSVGetFileFieldId
/usr/local/lib/libgeotiff.dylib(cpl_csv.o) definition of
_CSVGetFileFieldId
make[1]: ***
[/Users/williamk/Documents/src/unix/GRASS/grass50_exp_2003_06_28/
dist.powerpc-apple-darwin6.6/etc/bin/cmd/r.in.gdal] Error 1
GISGEN failure at STEP: src/raster/r.in.gdal
I've tried reordering the LIBES libs, and GDAL_LIBS & LIBES, in the
GMakefile for r.in.gdal, but that just causes other indirect
references.  This is beyond my porting experience so far to know what
it means and how to fix it.
William Kyngesburye <kyngchaos at charter.net>
http://webpages.charter.net/kyngchaos/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
RIP Douglas Adams 1952-2001
