[GRASS5] r.in.gdal compile problem - _a_ solution?
William K
woklist at charter.net
Thu Aug 14 10:30:31 EDT 2003
This seems to work - no problems running r.in.gdal yet:
1. build and install gdal without libgrass
2. build and install grass with gdal
3. build and install gdal with libgrass
and keep a copy of both gdal builds to swap when I need to rebuild
grass.
Just starting to get data into grass, so I haven't had a chance to test
mapserver with grass data yet.
>> Build GDAL *without* GRASS support, i.e. "configure --without-grass".
> Well, that does work, BUT I use gdal with mapserver as well, and
> (eventually) want to be able to serve up GRASS rasters. Didn't have
> this problem in GRASS 5.0.2, but I get it now there as well. I'm
> pretty sure I had libgrass in gdal then. I did recently update to
> Apple's gcc 3.3 release, and it has caused a few problems elsewhere,
> especially with c++ stuff (tho GDAL had no problems).
William Kyngesburye <kyngchaos at charter.net>
http://webpages.charter.net/kyngchaos/
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does
that remind me of? Ah, yes - life."
- Marvin
RIP Douglas Adams 1952-2001
