> > *d.barscale: ... > OK, fixed in CVS (release branch). The patch is ... > The other two problems: I darkly remember a newline fix, any > suggestions? Otherwise I'll dig into the details (commit archive). Are you sure that wasn't d.where (Revision 1.13)? That has proj code and is CVS/HEAD only. Hamish
