[GRASS5] Re: [GRASSLIST:1998] Re: Installing grass57_exp_2003_10_25 on MacX
Scott Mitchell smitch at mac.com
Wed Dec 10 10:53:15 EST 2003
Oops, sorry, I THOUGHT I was using shared libraries, but your email
made me check my config.status, and sure enough, that time around I
hadn't used the shared flag.
Just did a rebuild with it turned back on, and it still seems fine.
Oh, I also deleted the EXTRA_LIBS line from lib/proj/Makefile first.
All looks good.
Cheers,
Scott
On 10-Dec-03, at 10:24, Paul Kelly wrote:
> Hello Scott
> On Wed, 10 Dec 2003, Scott W Mitchell wrote:
>> On 9-Dec-03, at 05:36, Markus Neteler wrote:
>>> On Mon, Dec 08, 2003 at 09:39:22PM +0000, Paul Kelly wrote:
>>>> I also think this means all the EXTRA_LIBS lines can be removed from
>>>> the library Makefiles again now but since I haven't got an OSX
>>>> system to
>>>> test it I don't want to risk doing this. It's nice to see the
>>>> Makefiles tidy and as short as possible though.
>>> Generally agreed - someone with MacOSX system may try and post the
>>> result. I am too far from a Mac to try myself.
>> What constitutes a test ?  On an os 10.3 system, I went in to
>> lib/ogsf,
>> then moved to lib/gis figuring that's a better test, and removed the
>> EXTRA_LIBS file from the 2 makefiles, then recompiled.  Went smoothly,
>> and I can digitize a line, display rasters and run r.mapcalc.
> Just as long as it compiles (you are using shared libraries of
> course?) I
> think should be OK. Paul
Scott W. Mitchell		Scott_Mitchell at carleton.ca
Department of Geography and Environmental Studies
Carleton University, B349 Loeb Building (Office A209)
1125 Colonel By Drive, Ottawa, ON Canada K1S 5B6
+1-613-520-2600 ext 2695 Fax: 1-613-520-4301
