[GRASS5] Re: 57 compile error
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu Dec 11 16:14:04 EST 2003
On Thu, 11 Dec 2003, Kirk R. Wythers wrote:
> I have been working with different configure combinations for a 57
> build (see below) and now I am struggling with a nad2bin issue.
> The make error is:
> OBJ.powerpc-apple-darwin7.0.0/get_proj.o
> OBJ.powerpc-apple-darwin7.0.0/do_proj.o
> OBJ.powerpc-apple-darwin7.0.0/convert.o
> OBJ.powerpc-apple-darwin7.0.0/datum.o
> OBJ.powerpc-apple-darwin7.0.0/ellipse.o -lgrass_gis -lgrass_datetime
> -lintl -lproj -L/usr/local/lib -lgdal -o
> /Users/kirkw/tmp/grass57_exp_2003_12_06/dist.powerpc-apple-darwin7.0.0/
> lib/libgrass_gproj.dylib
> for i in FL.lla MD.lla TN.lla WI.lla WO.lla alaska.lla conus.lla
> hawaii.lla prvi.lla stgeorge.lla stlrnc.lla stpaul.lla ; do nad2bin <
> $i
> etc/nad/`echo $i | sed 's/.lla//'`; done
> /bin/sh: line 1: nad2bin: command not found
> make[2]: ***
> [/Users/kirkw/tmp/grass57_exp_2003_12_06/dist.powerpc-apple-
> darwin7.0.0/etc/nad] Error 127
> make[1]: *** [subdirs] Error 1
> make: *** [default] Error 1
Make sure you have PROJ installed properly. nad2bin comes with it and
should be installed in a directory somewhere in your path, e.g.
/usr/local/bin
