[GRASS5] 57 with postgres on OSX
Kirk R. Wythers
kwythers at umn.edu
Mon Dec 15 17:04:56 EST 2003
On Dec 15, 2003, at 2:19 PM, Glynn Clements wrote:
>> In ./db/drivers/postgres/Makefile
>> CRYPTLIB = -lcrypt
>> is hardcoded. Maybe this should go elsewhere into Platform.make
> Just remove that line, or change it to an empty definition, i.e.:
> CRYPTLIB =
> If you get any "undefined symbol" errors as a result, tell us what
> they are.
That did the trick Glynn. I set CRYPTLIB to empty and it built without
a hitch. Should I be on the lookout for any particular runtime issues
from that change?
> Glynn Clements <glynn.clements at virgin.net>
Kirk R. Wythers tel: 612.625.2261
Dept. of Forest Resources fax: 612.625.5212
University of Minnesota email: kwythers at umn.edu
