[GRASS5] [bug #2255] (grass) Problem exporting site map as DXF file
Request Tracker
grass-bugs at intevation.de
Fri Dec 19 04:53:55 EST 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=2255
Subject: Problem exporting site map as DXF file
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 5.0.3
Hi, my name is Stefano.
I have a site map with 40 points and i would export them as dxf file of points with Grass
5.0.3 under SuSE 8.2. With the sequence of commands: sitemap -> s.to.vect -> vector point
map -> v.out.ascii -> ASCII vector point map -> v.out.dxf -> output dxf file, i obtain a dxf file
with 4 layers "formally" correct, in the sense that a CAD program such Qcad open them
without error messages, but, as you can see below, the file do not contain any information
about the coordinates of points and so any graphic point is displayed. BTW, I have no
problems exporting in dxf vector maps of lines and polygons.
Can you give me some hints?
Thanks in advance!
Stefano Perona
0
SECTION
2
HEADER
9
$LIMMIN
10
404000.000000
20
5031000.000000
9
$LIMMAX
10
409000.000000
20
5035000.000000
0
ENDSEC
0
SECTION
2
TABLES
0
TABLE
2
LTYPE
70
1
0
LTYPE
2
CONTINUOUS
70
64
3
Solid line
72
65
73
0
40
0.0
0
ENDTAB
0
TABLE
2
LAYER
70
5
0
LAYER
2
0
70
0
62
7
6
CONTINUOUS
0
LAYER
2
AV_POZ_N_VECT at STEFANO
70
64
62
1
6
CONTINUOUS
0
LAYER
2
LV_POZ_N_VECT at STEFANO
70
64
62
2
6
CONTINUOUS
0
LAYER
2
LC_POZ_N_VECT at STEFANO
70
64
62
3
6
CONTINUOUS
0
LAYER
2
AC_POZ_N_VECT at STEFANO
70
64
62
4
6
CONTINUOUS
0
ENDTAB
0
ENDSEC
0
SECTION
2
ENTITIES
0
ENDSEC
0
EOF
-------------------------------------------- Managed by Request Tracker
