[GRASS5] [bug #1566] (grass) vector data select by attribute
Request Tracker grass-bugs at intevation.de
Sun Feb 2 23:37:03 EST 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=1566
Subject: vector data select by attribute
grass binary for platform: Compiled from Sources
GRASS Version: 5.0.0 (Aug 2002)
Improved support for selecting vector data by attribute (eg: 200m contours from a vector map of contour data) and to select from multiple maps to create a new map (or ideally to create a virtual map with pointers to the data, which may optionally be saved as a new map).
I'm not sure if the 5.1 data management in PostGreSQL/PostGIS will permit this through the use of db views, if GRASS 5.1 can access such views as maps. If so, then the wish is coming true :-)
Thanks,
   Brent Wood
-------------------------------------------- Managed by Request Tracker
