[GRASS5] creating a new DEFAULT_WIND by copying the current WIND
Glynn Clements
glynn.clements at virgin.net
Sun Feb 9 23:11:48 EST 2003
Moritz Lennert wrote:
> I'm working on a chapter on the "region" for the GRASS tutorial and I have
> a question concerning altering the default region. What arguments (other
> than not wanting to have users play around in the GRASS database) are
> there against creating a current region that is larger than the default
> region and then replacing the DEFFAULT_WIND with the WIND file (or a named
> region file) containing the parameters of that larger region ? Would any
> of the existing maps suffer from this ?
There isn't any reason why the default region shouldn't be changed.
It's arguable that g.region should have an option to update the
default region instead of the current one, although I don't know what
would be involved in implementing this.
Glynn Clements <glynn.clements at virgin.net>
