[GRASS5] [Updated] Changes between 5.0.1 release and current CVS head
Glynn Clements
glynn.clements at virgin.net
Wed Feb 12 05:41:23 EST 2003
An updated version is attached. This reflects the situation after the
recent sync; that consisted of whole-file changes, i.e. new files, or
files which were replaced by the version from the CVS head.
The remaining differences correspond to cases where one or more of the
following apply:
1. The author advised against inclusion.
2. I advised against inclusion.
3. The significance of the change isn't immediately obvious, and
nobody specifically recommended inclusion.
4. There are multiple changes to a single file, and at least one of
the changes is subject to 1-3 above.
5. The change was made since the merge.
Some of these may yet make it into 5.0.2, mostly depending upon
someone being willing to advocate inclusion.
Glynn Clements <glynn.clements at virgin.net>
configure
configure.in
Remove postgres[_fe].h checks
src/include/config.h.in
Remove HAVE_POSTGRES[_FE]_H
Add HAVE_LIBPQ_FE_H
src/CMD/generic/gmake.sh
Allow C++ files (incomplete)
- html/html/v.rm.dangles.html
Removed
html/vector.html
Remove v.rm.dangles xref
html/html/d.vect.pg.html
-e
html/html/r.fillnulls.html
html/html/r.flow.html
html/html/r.flowmd.html
html/html/s.surf.rst.html
html/html/s.vol.rst.html
html/html/v.surf.rst.html
Change URLs (NCSU -> UIUC)
html/html/r.out.ascii.html
-M -> -s
ASCII -> binary
input -> inout
??? this doesn't appear to make sense, or agree with the source code
html/index.html
html/searchhtml.html
index2.html -> index.html
html/html/r.proj.html
html/html/s.proj.html
html/html/v.proj.html
Generalised datum transformations
Remove m.proj xref
src/raster/r.proj/cmd/bordwalk.c
src/raster/r.proj/cmd/main.c
src/sites/s.proj/main.c
src/mapdev/v.proj/local_proto.h
src/mapdev/v.proj/main.c
src/tcltkgrass/module/v.proj
Fix v.proj tcltkgrass module
src/general/g.region/cmd/printwindow.c
src/mapdev/v.in.gshhs/main.c
src/misc/m.ll2db/main.c
src/raster/r.sun/main.c
src/raster/r.sunmask/g_solposition.c
src/sites/s.datum.shift/main.c
Don't call pj_zero_proj()
locale/Gmakefile
Add tcltkgrass, textintro targets
src/tcltkgrass/main/gis_set.tcl
src/tcltkgrass/tcltkgrass
+ locale/ru/tcltkgrass/
I81N
src.contrib/GMSL/NVIZ2.2/doconfigure
- src.contrib/GMSL/NVIZ2.2/src/query_postgr_dummy.c
- src.contrib/GMSL/NVIZ2.2/src/query_postgr_orig.c
Remove query_postgr_{orig,dummy}.c
src.contrib/GMSL/NVIZ2.2/src/query_postgr.c
src.contrib/GMSL/NVIZ2.2/scripts/fileBrowser.tcl
Default to cwd instead of $HOME
src.contrib/GMSL/NVIZ2.2/scripts/panel_kanimator.tcl
src.contrib/GMSL/NVIZ2.2/scripts/panel_main.tcl
src.contrib/GMSL/NVIZ2.2/src/anim_support.c
src.contrib/GMSL/NVIZ2.2/src/change_view.c
src.contrib/GMSL/NVIZ2.2/src/getCat.c
src.contrib/GMSL/NVIZ2.2/src/init_commands.c
src.contrib/GMSL/NVIZ2.2/src/interface.h
src.contrib/GMSL/NVIZ2.2/src/position.c
??? (Bob)
- src.contrib/GMSL/NVIZ2.2/src/buildInfxQry.c
- src.contrib/GMSL/NVIZ2.2/src/infx.h
- src.contrib/GMSL/NVIZ2.2/src/runInfxQry.c
+ src.contrib/GMSL/NVIZ2.2/src/buildPg.c
+ src.contrib/GMSL/NVIZ2.2/src/pg.h
+ src.contrib/GMSL/NVIZ2.2/src/runPg.c
src.contrib/GMSL/NVIZ2.2/src/Gmakefile
Infx -> Pg
locale/ru/LC_MESSAGES/d.rast.pg.po
locale/ru/LC_MESSAGES/d.site.pg.po
locale/ru/LC_MESSAGES/d.vect.pg.po
locale/ru/LC_MESSAGES/d.what.r.pg.po
locale/ru/LC_MESSAGES/d.what.s.pg.po
locale/ru/LC_MESSAGES/d.what.v.pg.po
locale/ru/LC_MESSAGES/g.column.pg.po
locale/ru/LC_MESSAGES/g.select.pg.po
locale/ru/LC_MESSAGES/g.stats.pg.po
locale/ru/LC_MESSAGES/g.table.pg.po
locale/ru/LC_MESSAGES/pg.in.dbf.po
locale/ru/LC_MESSAGES/v.reclass.pg.po
locale/ru/LC_MESSAGES/v.to.pg.po
Various
- src.garden/grass.postgresql/d.rast.pg/buildInfxQry.c
- src.garden/grass.postgresql/d.rast.pg/runInfxFile.c
- src.garden/grass.postgresql/d.site.pg/buildInfxQry.c
- src.garden/grass.postgresql/d.site.pg/runInfxFile.c
- src.garden/grass.postgresql/d.vect.pg/buildInfxQry.c
- src.garden/grass.postgresql/d.vect.pg/runInfxFile.c
- src.garden/grass.postgresql/d.what.r.pg/buildInfxQry.c
- src.garden/grass.postgresql/d.what.r.pg/runInfxQry.c
- src.garden/grass.postgresql/d.what.s.pg/buildInfxQry.c
- src.garden/grass.postgresql/d.what.s.pg/infx.h
- src.garden/grass.postgresql/d.what.s.pg/runInfxFile.c
- src.garden/grass.postgresql/d.what.v.pg/buildInfxQry.c
- src.garden/grass.postgresql/d.what.v.pg/runInfxQry.c
- src.garden/grass.postgresql/g.column.pg/infx.h
- src.garden/grass.postgresql/g.column.pg/infxColumn.c
- src.garden/grass.postgresql/g.stats.pg/infx.h
- src.garden/grass.postgresql/g.stats.pg/infxStats.c
- src.garden/grass.postgresql/g.table.pg/infxTable.c
- src.garden/grass.postgresql/v.reclass.pg/buildInfxQry.c
- src.garden/grass.postgresql/v.reclass.pg/runInfxFile.c
- src.garden/grass.postgresql/v.to.pg/buildInfxQry.c
- src.garden/grass.postgresql/v.to.pg/runInfxFile.c
+ src.garden/grass.postgresql/d.rast.pg/buildPg.c
+ src.garden/grass.postgresql/d.rast.pg/runPg.c
+ src.garden/grass.postgresql/d.site.pg/buildPg.c
+ src.garden/grass.postgresql/d.site.pg/runPg.c
+ src.garden/grass.postgresql/d.vect.pg/buildPg.c
+ src.garden/grass.postgresql/d.vect.pg/runPg.c
+ src.garden/grass.postgresql/d.what.r.pg/buildPg.c
+ src.garden/grass.postgresql/d.what.r.pg/runPg.c
+ src.garden/grass.postgresql/d.what.s.pg/buildPg.c
+ src.garden/grass.postgresql/d.what.s.pg/runPg.c
+ src.garden/grass.postgresql/d.what.v.pg/buildPg.c
+ src.garden/grass.postgresql/d.what.v.pg/runPg.c
+ src.garden/grass.postgresql/g.column.pg/pgColumn.c
+ src.garden/grass.postgresql/g.stats.pg/pgStats.c
+ src.garden/grass.postgresql/g.table.pg/pgTable.c
+ src.garden/grass.postgresql/v.reclass.pg/buildPg.c
+ src.garden/grass.postgresql/v.reclass.pg/runPg.c
+ src.garden/grass.postgresql/v.to.pg/buildPg.c
+ src.garden/grass.postgresql/v.to.pg/runPg.c
src.garden/grass.postgresql/d.rast.pg/Gmakefile
src.garden/grass.postgresql/d.site.pg/Gmakefile
src.garden/grass.postgresql/d.vect.pg/Gmakefile
src.garden/grass.postgresql/d.what.r.pg/Gmakefile
src.garden/grass.postgresql/d.what.s.pg/Gmakefile
src.garden/grass.postgresql/d.what.v.pg/Gmakefile
src.garden/grass.postgresql/g.column.pg/Gmakefile
src.garden/grass.postgresql/g.stats.pg/Gmakefile
src.garden/grass.postgresql/v.reclass.pg/Gmakefile
src.garden/grass.postgresql/v.to.pg/Gmakefile
Infx -> Pg
src.garden/grass.postgresql/g.table.pg/Gmakefile
Infx -> Pg
I18N
- src.garden/grass.postgresql/d.what.s.pg/graphics.h
- src.garden/grass.postgresql/d.what.s.pg/returns.c
+ src.garden/grass.postgresql/d.what.s.pg/what.h
- src.garden/grass.postgresql/g.column.pg/column.h
- src.garden/grass.postgresql/g.column.pg/delcr.c
- src.garden/grass.postgresql/g.stats.pg/stats.h
src.garden/grass.postgresql/d.rast.pg/dbrast.h
src.garden/grass.postgresql/d.rast.pg/getAllOpts.c
src.garden/grass.postgresql/d.rast.pg/getSopts.c
src.garden/grass.postgresql/d.rast.pg/main.c
src.garden/grass.postgresql/d.site.pg/dbsite.h
src.garden/grass.postgresql/d.site.pg/getAllOpts.c
src.garden/grass.postgresql/d.site.pg/getSopts.c
src.garden/grass.postgresql/d.site.pg/main.c
src.garden/grass.postgresql/d.site.pg/plotsite.c
src.garden/grass.postgresql/d.vect.pg/bsearch.c
src.garden/grass.postgresql/d.vect.pg/dbvect.h
src.garden/grass.postgresql/d.vect.pg/find.c
src.garden/grass.postgresql/d.vect.pg/getAllOpts.c
src.garden/grass.postgresql/d.vect.pg/getSopts.c
src.garden/grass.postgresql/d.vect.pg/main.c
src.garden/grass.postgresql/d.vect.pg/plotCat.c
src.garden/grass.postgresql/d.what.r.pg/getAllOpts.c
src.garden/grass.postgresql/d.what.r.pg/getCat.c
src.garden/grass.postgresql/d.what.r.pg/getSopts.c
src.garden/grass.postgresql/d.what.r.pg/main.c
src.garden/grass.postgresql/d.what.r.pg/opencell.c
src.garden/grass.postgresql/d.what.r.pg/what.h
src.garden/grass.postgresql/d.what.s.pg/getAllOpts.c
src.garden/grass.postgresql/d.what.s.pg/getArea.c
src.garden/grass.postgresql/d.what.s.pg/getSopts.c
src.garden/grass.postgresql/d.what.s.pg/main.c
src.garden/grass.postgresql/d.what.v.pg/getAllOpts.c
src.garden/grass.postgresql/d.what.v.pg/getCat.c
src.garden/grass.postgresql/d.what.v.pg/getSopts.c
src.garden/grass.postgresql/d.what.v.pg/main.c
src.garden/grass.postgresql/d.what.v.pg/openvect.c
src.garden/grass.postgresql/d.what.v.pg/what.h
src.garden/grass.postgresql/g.column.pg/main.c
src.garden/grass.postgresql/g.select.pg/getdbname.c
src.garden/grass.postgresql/g.select.pg/listdb.c
src.garden/grass.postgresql/g.select.pg/main.c
src.garden/grass.postgresql/g.stats.pg/main.c
src.garden/grass.postgresql/g.table.pg/main.c
src.garden/grass.postgresql/pg.in.dbf/main.c
src.garden/grass.postgresql/pg.in.dbf/pgdump.c
src.garden/grass.postgresql/tutorial/index.html
src.garden/grass.postgresql/v.in.arc.pg/pgdump.c
src.garden/grass.postgresql/v.reclass.pg/dbvect.h
src.garden/grass.postgresql/v.reclass.pg/getAllOpts.c
src.garden/grass.postgresql/v.reclass.pg/getSopts.c
src.garden/grass.postgresql/v.reclass.pg/main.c
src.garden/grass.postgresql/v.to.pg/bsearch.c
src.garden/grass.postgresql/v.to.pg/dbvect.h
src.garden/grass.postgresql/v.to.pg/find.c
src.garden/grass.postgresql/v.to.pg/getAllOpts.c
src.garden/grass.postgresql/v.to.pg/getSopts.c
src.garden/grass.postgresql/v.to.pg/main.c
src.garden/grass.postgresql/v.to.pg/plotCat.c
Infx -> Pg
Tidying
src/display/d.what.sites/local_proto.h
src/display/d.what.sites/main.c
src/display/d.what.sites/what.c
Flashing sites when selecting a site
html/html/d.what.vect.html
src/display/d.what.vect/cmd/Gmakefile
src/display/d.what.vect/cmd/what.c
src/display/d.what.vect/cmd/what.h
+ src/display/d.what.vect/cmd/flash.c
Flashing polygon/line when selecting a vector
src/general/g.setproj/get_num.c
src/general/g.setproj/local_proto.h
src/general/g.setproj/main.c
??? (Eric)
src/include/geo.h
??? (Eric)
src/libes/gis/geo_init.c
??? (Eric)
src/general/init/Gmakefile
+ src/general/init/license.txt
+ locale/ru/grass_intro.txt
+ locale/ru/license.txt
I18N (license, grass_intro)
src/general/init/init.sh
clean up temp files on exit
src/general/init/chk_dbase.c
MINGW32
src/general/init/grass.src
Trap signals
src/imagery/i.ortho.photo/photo.rectify/write.c
Error messages
src/include/projects.h
src/libes/gis/closecell.c
src/libes/gis/env.c
src/libes/gis/fork.c
src/libes/gis/get_datum_name.c
src/libes/gis/gets.c
src/libes/gis/intr_char.c
src/libes/gis/list.c
src/libes/gis/mapset_msc.c
src/libes/gis/popen.c
src/libes/gis/remove.c
src/libes/gis/set_prior.c
src/libes/gis/system.c
src/libes/gis/unix_socks.c
src/libes/gis/user_config.c
src/libes/gis/whoami.c
MINGW32
unlink() -> remove()
Conditionalise SIGQUIT handling
I18N
src/libes/gis/datum.table
ETRS89 comment
Add "ire65" (Ireland 1965)
src/libes/gis/state83
3200: x_0: 0.6e+06 -> 0.60960122e+06
src/libes/lock/lock.c
src/libes/lock/unlock.c
MINGW32
src/libes/ogsf/GK2.c
src/libes/ogsf/GS2.c
src/libes/ogsf/gk.c
src/libes/ogsf/gpd.c
src/libes/ogsf/gsd_prim.c
src/libes/ogsf/local_proto.h
??? (Bob)
src/libes/proj/Gmakefile
src/libes/proj/do_proj.c
src/libes/proj/get_proj.c
- src/libes/proj/datum_shift.c
- src/libes/proj/do_proj_nad.c
src/libes/proj/pj_datums.c
src/libes/proj/pj_ellps.c
Add missing underscores
src/libes/raster/Gmakefile
src/libes/raster/io.c
src/libes/raster/new_io.c
src/libes/raster/parse_mon.c
+ locale/ru/LC_MESSAGES/libraster.po
I18N
MINGW32
src/libes/vask/V_support.c
src/libes/vect32/Vlib/open1.c
src/libes/vect32/bin_digit/bin_digit.c
src/libes/vect32/georef/bin_point.c
src/libes/vect32/georef/bin_reg.c
src/libes/vect32/georef/set_key.c
src/libes/vect32_64/Vlib/open1.c
MINGW32
src/mapdev/v.in.dgn/Gmakefile
src/mapdev/v.in.dgn/README
src/mapdev/v.in.dgn/main.c
html/html/m.in.e00.html
src/misc/m.in.e00/info.c
src/misc/m.in.e00/main.c
list=
src/misc/m.proj/geo_func.c
src/misc/m.proj/local_proto.h
src/misc/m.proj/main.c
src/misc/m.proj/process.c
src/misc/m.proj2/geo_func.c
src/misc/m.proj2/input.c
src/misc/m.proj2/local_proto.h
src/misc/m.proj2/main.c
src/misc/m.proj2/process.c
src/scripts/contrib/d.rast.leg/d.rast.leg
src/scripts/contrib/r.univar/r.univar
html/html/d.legend.html
src/tcltkgrass/module/d.legend
-o, maxfontsize=
+ src.nonGPL/
Removed from release branch
+ src.contrib/GMSL/r.simwe/
Added
+ tools/diff.sh
Added
