[GRASS5] [Updated] Changes between 5.0.1 release and current CVS head
Markus Neteler
neteler at itc.it
Wed Feb 12 06:13:41 EST 2003
On Wed, Feb 12, 2003 at 10:41:23AM +0000, Glynn Clements wrote:
Content-Description: message body and .signature
> An updated version is attached. This reflects the situation after the
> recent sync; that consisted of whole-file changes, i.e. new files, or
> files which were replaced by the version from the CVS head.
Thanks for your efforts, Glynn!
> - html/html/v.rm.dangles.html
> Removed
> html/vector.html
> Remove v.rm.dangles xref
The both above may go into 5.0.2. It simply fixes the problem
that the man page was not written earlier.
> html/html/d.vect.pg.html
> -e
> html/html/r.fillnulls.html
> html/html/r.flow.html
> html/html/r.flowmd.html
> html/html/s.surf.rst.html
> html/html/s.vol.rst.html
> html/html/v.surf.rst.html
> Change URLs (NCSU -> UIUC)
The old server is dead. That's why the updated urls should
reach 5.0.2.
> html/html/r.out.ascii.html
> -M -> -s
> ASCII -> binary
> input -> inout
> ??? this doesn't appear to make sense, or agree with the source code
In my HEAD version I have
r.out.ascii help
Description:
Converts a raster map layer into an ASCII text file.
Usage:
r.out.ascii [-hsMi] input=name [output=name] [dp=value] [width=value]
[null=name]
Flags:
-h Suppress printing of header information
-s Write SURFER (Golden Software) ASCII grid
-M Write MODFLOW (USGS) ASCII array
-i Force output of integer values
Parameters:
input Name of an existing raster map
output Name of an output ASCII grid map (use out=- for stdout)
dp Number of significant digits (floating point only)
width Number of values printed before wrapping a line
null String to represent null cell (GRASS grid only)
default: *
And
reflects this (since some days) [another reason to use G_usage_html()].
> html/index.html
> html/searchhtml.html
> index2.html -> index.html
Why not? The page index2.html doesn't exist any more.
> src/tcltkgrass/module/v.proj
> Fix v.proj tcltkgrass module
I vote for yes.
> src/mapdev/v.in.dgn/Gmakefile
> src/mapdev/v.in.dgn/README
> src/mapdev/v.in.dgn/main.c
This was requested a few times on the user list, maybe we can
add it.
> html/html/m.in.e00.html
> src/misc/m.in.e00/info.c
> src/misc/m.in.e00/main.c
> list=
...Roger Miller, if I recall correctly.
> src/scripts/contrib/r.univar/r.univar
I vote for no.
> html/html/d.legend.html
> src/tcltkgrass/module/d.legend
> -o, maxfontsize=
Being author of -o, maxfontsize=, I vote for eliminating them.
The module is in hands of Hamish Bowman now.
So: yes.
Markus
