[GRASS5] [Updated] Changes between 5.0.1 release and current CVS head
Glynn Clements
glynn.clements at virgin.net
Thu Feb 13 16:33:56 EST 2003
Glynn Clements wrote:
> html/html/r.fillnulls.html
> html/html/r.flow.html
> html/html/r.flowmd.html
> html/html/s.surf.rst.html
> html/html/s.vol.rst.html
> html/html/v.surf.rst.html
> Change URLs (NCSU -> UIUC)
> - html/html/v.rm.dangles.html
> Removed
> html/vector.html
> Remove v.rm.dangles xref
> html/html/r.out.ascii.html
> -M -> -s
> ASCII -> binary
> input -> inout
> ??? this doesn't appear to make sense, or agree with the source code
It appears that these were just an artifact of my copy of the head
being slightly older than the release branch when I made the diffs.
I've appended a list of the recent changes to the head which *aren't*
accounted for in my last summary. Most of these appear to be related
to the datum conversion stuff, and so aren't applicable to the release
branch.
Glynn Clements <glynn.clements at virgin.net>
+ src.garden/grass.postgresql/v.in.arc.pg/DEPRECATED
+ src.garden/grass.postgresql/v.in.shape.pg/DEPRECATED
+ src/misc/m.proj/DEPRECATED
Add notes regarding suitable alternatives
binaryInstall.src
Allow for _tar.{gz,bz2} (for web browsers which modify the filename)
documents/cygwin_grass50bininstall.html
Add comment regarding whitespace in paths
Remove section 3a (SunRPC package; now part of Cygwin)
Renumber X11 Tcl/Tk section from 3b to 4
Renumber subsequent sections
documents/cygwin_grass50compile.html
Remove section 3 (SunRPC package; now part of Cygwin)
Renumber X11 section from 4a to 3
Renumber X11 Tcl/Tk section from 4b to 4
html/html/m.proj2.html
Elaborate upon datum transformations
src.contrib/GMSL/r.simwe/Gmakefile
Add r.sim.sediment
src.garden/grass.postgresql/Gmakefile
Fix comment typo (boing -> being)
src.garden/grass.postgresql/pg.in.dbf/Gmakefile
Hardcoded paths - CHANGE REVERTED
src.garden/grass.postgresql/tutorial/index.html
src/CMD/VERSION
2002 -> 2003 (typo)
src/CMD/lists/GRASS
Add v.label
Disable m.proj
Add r.terraflow
Add r.simwe (disabled)
src/display/d.sites/cmd/draw_point.c
Use G_adjust_easting()
src/general/g.region/cmd/printwindow.c
src/mapdev/v.digit/map_init_new.c
src/mapdev/v.in.gshhs/main.c
src/mapdev/v.mkquads/convert.c
src/misc/m.ll2db/main.c
src/raster/r.sun/main.c
src/raster/r.sunmask/g_solposition.c
src/sites/s.datum.shift/main.c
ellps=
src/libes/gis/Gmakefile
Use tabs instead of spaces
src/libes/image3/convert_ll.c
Ellipse handling
src/misc/m.proj2/TODO
Remove "A datum is silently ignored" comment
src/misc/m.proj2/main.c
Remove pj_zero_proj() calls
src/misc/m.proj2/process.c
Lat/Lon location handling
+ src/tcltkgrass/module/r.proj
+ src/tcltkgrass/module/s.proj
src/tcltkgrass/main/menu.tcl
Add interfaces to [rs].proj
