[GRASS5] [Updated] Changes between 5.0.1 release and current CVS head
Markus Neteler
neteler at itc.it
Sun Feb 16 09:12:12 EST 2003
On Thu, Feb 13, 2003 at 09:33:56PM +0000, Glynn Clements wrote:
> documents/cygwin_grass50bininstall.html
> Add comment regarding whitespace in paths
> Remove section 3a (SunRPC package; now part of Cygwin)
> Renumber X11 Tcl/Tk section from 3b to 4
> Renumber subsequent sections
> documents/cygwin_grass50compile.html
> Remove section 3 (SunRPC package; now part of Cygwin)
> Renumber X11 section from 4a to 3
> Renumber X11 Tcl/Tk section from 4b to 4
yes, both updates are recommended to reduce confusion.
> src.contrib/GMSL/r.simwe/Gmakefile
> Add r.sim.sediment
no to all r.sim* (it's not yet ready for release)
> src.garden/grass.postgresql/Gmakefile
> Fix comment typo (boing -> being)
ok
> src.garden/grass.postgresql/pg.in.dbf/Gmakefile
> Hardcoded paths - CHANGE REVERTED
ok
> src.garden/grass.postgresql/tutorial/index.html
yes. Strange characters removed, polished a bit.
> src/CMD/VERSION
> 2002 -> 2003 (typo)
yes, please.
> src/CMD/lists/GRASS
> Add v.label
> Disable m.proj
> Add r.terraflow
> Add r.simwe (disabled)
I think r.terraflow should be commented if the C++ section is
not present in the make system.
> src/display/d.sites/cmd/draw_point.c
> Use G_adjust_easting()
sounds to be important according to the message of Eric.
> src/libes/gis/Gmakefile
> Use tabs instead of spaces
yes, just for 5.1 compliance (when diff'ing).
> + src/tcltkgrass/module/r.proj
> + src/tcltkgrass/module/s.proj
> src/tcltkgrass/main/menu.tcl
> Add interfaces to [rs].proj
yes, was obviously missing.
Thanks,
Markus
