[GRASS5] CVS Write Access Instructions improved
Bernhard Reiter bernhard at intevation.de
Wed Feb 19 15:26:10 EST 2003
I've improved the instruction for people having CVS write access.
http://freegis.org//grass/howto_grass-sshcvs.en.html
It now tells you how you can use openssh's config file
to set the port number. Thus you don't need the ssh wrapper
for this method.
For people using many CVS servers this will not hose CVS_RSH
for other ssh access servers.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030219/58786073/attachment.bin
