[GRASS5] SG3d and g.parser
John Gillette
JGillette at rfmd.com
Wed Feb 19 17:38:38 EST 2003
Glynn,
g.parser appears to be one of those programs not on the CMD/list
so it wasn't compiled on my system. When I compile, I get an
undefined symbol reference (setenv) in main.o
I have enclosed to error message.
Let me ask a few more questions.
As an example:
my_script map=f00
my_script will define all the required parameters for the parser
in the top portion (as in test.sh) similar to a C program.
my_script will have on the command line none, some, or all of
the required parameters. The parser will get the command line
parameters and ask for any missing parameters. Is this
correct?
The rest looks straight forward.
John
SRC = /scratch/grass500/grass-5.0.0/src
CMD = /scratch/grass500/grass-5.0.0/src/CMD
UNUSED = /scratch/grass500/grass-5.0.0/unused
HEADER = head.sparc-sun-solaris2.7
ARCH = sparc-sun-solaris2.7
GISBASE = /scratch/grass500/grass-5.0.0/dist.sparc-sun-solaris2.7
VERSION = 5.0.0 August 2002
/scratch/grass500/grass-5.0.0/src/general/g.parser
mkdir OBJ.sparc-sun-solaris2.7
make -f OBJ.sparc-sun-solaris2.7/make.rules
gcc -I/scratch/grass500/grass-5.0.0/src/include -g -O2 -c main.c -o OBJ.sparc-sun-solaris2.7/main.o
gcc -L/scratch/grass500/grass-5.0.0/src/libes/LIB.sparc-sun-solaris2.7 -o /scratch/grass500/grass-5.0.0/dist.sparc-sun-solaris2.7/etc/bin/cmd/g.parser OBJ.sparc-sun-solaris2.7/main.o -lgis -lm -lnsl -lz -lsocket -lnsl
Undefined first referenced
symbol in file
setenv OBJ.sparc-sun-solaris2.7/main.o
ld: fatal: Symbol referencing errors. No output written to /scratch/grass500/grass-5.0.0/dist.sparc-sun-solaris2.7/etc/bin/cmd/g.parser
*** Error code 1
make: Fatal error: Command failed for target `/scratch/grass500/grass-5.0.0/dist.sparc-sun-solaris2.7/etc/bin/cmd/g.parser'
