[GRASS5] v.digit color name mismatch
Helena Mitasova
hmitaso at unity.ncsu.edu
Mon Feb 24 10:16:09 EST 2003
cheg01 at attbi.com wrote:
>----- Original Message -----
>From: "Radim Blazek" <blazek at itc.it>
>To: <cheg01 at attbi.com>; <grass5 at grass.itc.it>
>Sent: Monday, February 24, 2003 12:53 AM
>Subject: Re: [GRASS5] v.digit color name mismatch
>>Hi Chris,
>>I see that you are working on v.digit, I would like to only note
>>that work on v.digit in 5.1 was also started:
>>http://mpa.itc.it/radim/g51/v.digit3.png
>>Radim
>I suspect that 5.0 will continue to have a large user base for some years
>to come. Is there an expeced release date for 5.1?
Chris, if you are doing anything with vector modules I are greatly
encourage you to look at 5.1
and coordinate your work with Radim. The vector capabilities in 5.0 are
not adequate
and we all need to work on getting 5.0 merged with 5.1 as soon as
possible so that we can have a working version
of GRASS5.1 with everything in it - I expect that people will switch to
GRASS5.1 as soon as it becomes
usable because of its vector and database support, so I would not put
much effort in fixing 5.0 vector stuff.
This is just my view, others may see it differently.
Helena
>_______________________________________________
>grass5 mailing list
>http://grass.itc.it/mailman/listinfo/grass5
